telewy
Zawartość dodana przez telewy
  1. Serse, Sorry that I took so long but I had not enough knowledge to write something valuable to you. Fortunately some other guys from forum helped me to write answer. It looks that problem with Explosion is that you use ignition and during ignition process boiler produces lots of gas which explodes when first fire appears. It might be a problem that pressure of air in your chimney is not enough to get of rid gases from boiler. Also it might be cause by pellet quality. Solution for it is very simple, you have to turn boiler to not use automatic inflame. After boiler starts fire then it keeps fire and not use ignition at all. This mode is called „supportive mode” (I don’t know proper translation for it). Most of time boiler is still and after time set in Estyma controller it feeds fuel and switch on fan for while. Then again it goes still. When you go to boiler menu, under position BURNER you will find following parameters: a. Burner power 20% b. Fuel fuel 2 c. Fan at light 20 d. S-by still[min] 30 e. S-by feel[sec] 10 f. S-by fan[sec] 20 These parameters are taken from my granpal 15kw but in your case you should start with s-by still=20. Be sure to have fuel parameter set to fuel2 which is pellet. In general me and lots of folks from forum don’t use ignition at all. When I need fire boiler I use staff that usually I use to fire grill. Usually I need to do that only few times per year, usually when I clean my boiler. And don’t worry, when your boiler works in „supportive mode” it doesn’t consume much pellet. I think this should solve your problem with explosion. Best regards, tomasz
  2. Electrican, dobrze że o tym piszesz. W weekend byłem zalatany ale myślałem co mu odpisać, bo nie widziałem przyczyny tych jego wybuchów. Postaram się coś sklecić na podstawie Twojego postu. Ja mu zasugeruję pracę tak jak ja mam czyli podtrzymanie. Nie do końca jarzę "działanie w podtrzymaniu ze stałym korytarzem temperaturowym oraz wybór sposobu palenia bez zapalarki" więc nie chcę mieszać. Pozdr, tomek
  3. Serse, Sounds well, looks that your boiler works fine. Boiler works exactly as you describe, it doesn’t stop when room regulator temperatue is reached. It keeps internal temperature according to parameters set in estyma (if boiler temperature is set to 65 estyma stops heating boiler at 65+10=75 and starts heating when temperature goes down to 65-10=55. >>What does "Shift" refers to? What is it for? To be honest I don't use this parameter but this parameter it is for changing of temperature of CO. In manual there is picture showing curve for curve=1.2 and shift equal 0 and +/-10. This picture on horizontal axis has outdoor temperature but in case when there is not outdoor sensor 0 degree must be assumed for outdoor temperature. So simply adding some values to SHIFT you raise temperature for CO according to curve on this picture. The last question (cause it is late now) I understand that when mixer is opening, it should be "01" on the display, but it is always 00. What could be the reason? Yes, you are right. When mixer is opening display shows 01, when it’s closing display shows 00. When mixer stops 01 or 00 disappears. Cheers, Tomek
  4. Hi serse, I will try to help you but I am only casual user of Granpal boiler. I have read your story and just wonder if you had red any Granpal manual? Using this boiler is quite easy but you have followed some rules described in manual. Anyway I will try to answer your question so hopefully you will get rid of your problems. I have some problems with English names for some pieces of heating systems so I will try to describe them in my words to have common understanding what we are talking about. The first think boiler can work in 2 different modes: 1. one mode is when fire is always kept in boiler. During this mode when boiler is not working (not heating hose) every 30 min boiler out small amount of pellets and make for short time (20-30s) wind just to keep cinder 2. the second mode is one when boiler is not working it is switch off and when it starts to heat house first it use fire igniter to start fire pellet. I don’t use this mode so I don’t know much about it. But I know there are some relations between boiler temperature and exhaust temperature, I thin exhaust temperature must be below boiler temperature. Solution for your problem might be just to open upper door of boiler (the one which covers spirals). But most of the guys on forum do not recommend using this mode, preferable is the first one and when you have to start up boiler you do it manually with some lightwood (think you use when you want to fire your grill). In my installation I have no floor heating only heaters on the walls, I don’t use weather sensor, I use room sensor, I have 4 way mixer, my installation is pretty simple. I use manual mode of boiler. For further I will use following abbreviations CO – for heating house installation CW – for water system installation (water you use for washing) -the room regulator (regulator pokojowy) how does it work with the boiler? When the set temperature is reached, the regulator stops the boiler, or not ? (it is slowing it down, or stops it) Answer is No, room regulator doesn’t stop boiler. It sends signal to close mixer. Depending on your parameters setup in boiler driver there are few possibilities: 1. in general CO pomp is working always even when temperature in room is higher then on your room regulator. This pomp is switch off only in one case when parameter in menu decline temperature is equal 40 degree. BTW, I am writing this from my work and have no access at the moment to English menu of granpal, I will check proper names today on evening. I other cases CO pomp is always working. 2. Depending on decline temperature set up in boiler menu, boiler keeps different temperatures in CO installation when room regulator is off. The rule is if decline temperature is lower than CO temperature is higher. Actual CO temperature you can always check on granpal menu. CO temperature also depends on parameter “KRZYWA” CURVE??? This parameters is usually set as 0.8 or 1.0 or 1.2. Maximum value is 1.6. If it is higher the 3. CO temp is also higher. I thing when you use weather sensor it changes value of this CURVE parameter depending on outside temperature. 4. In my case boiler is keeping always high temperature, the one set up in menu “KOCIOL” BOILER???, I have it set to 67 degree. There are some hysteresis so in reality my boiler temp is kept between something like 57 and 77. There are also parameter you can extend these values. It means that in my case boiler is always hot. And when room regulator is on boiler gets signal to put hot water in CO installation. When room regulator is on water which is push into CO installation has higher temperature, something like 60 degree or higher. I don’t know how it works in case of floor heating system, as definitely you have to keep temperature in installation quite low. As I said when I am at my home I will look at my boiler English menu I will try to add some more accurate examples. To be honest I have no idea about your explosions. To let you know one of our colleagues described on forum similar case but it happened when boiler was hot and there power was switched off. Also I don’t have any smoke in my boiler at all, if you have smoke in hopper something is wrong. Very important thing is to have proper pressure of air in your chimney and proper thrust??? (thing that makes that smoke goes upper in chimney). Please feel free ask questions, step by step I hope we solve your problems. Regards, tomek
  5. Witam, Ja powoli też zbieram się za taki układ awaryjny, jest to jak na razie jedyna bolączka która mnie denerwuje z tym piecem. Zależy mi tylko i wyłącznie, w momencie zanika napięcia z sieci, na przestawieniu pieca w tryb podtrzymania do momentu powrotu prądu z sieci. A ponieważ jestem dyletantem to chętnie posłucham. Z tych rzeczy co napisałeś wydaje mi się, że moc nap. podaj. [W] 90 i moc motoreduktora [W] 90 to jedno i to samo. Co do Twojego zużycia pelletu to jeśli przez całą zimę spaliłem 1800kg czy 2200kg to jestem w szoku. Napisz dokładnie co rozumiesz przez sezon. Bo u mnie zużycie rocznie wynosi coś koło 5,5tony, a grzeję dom 165m + garaż 40m. Pozdr, tomek
  6. Jak masz zawór mieszający to on raz puszcza cieplejszą, raz zimniejszą, tak aby temperatura powrotu nie była za niska. Można taki zawór przestawić w tryb ręczny i wtedy idzie woda w miarę równa. Nie mniej ja bym się tym nie przejmował. Ostatniej Wielkanocy wyjechałem z chaty i wtedy nawaliło mnóstwo śniegu i pozrywało linie elektryczne, pradu u mnie nie było prawie 3 dni. Jak wróciłem w domu temperatura była coś koło 12 stopni, puściłem wyższą temperaturę w kaloryfery i chyba gdzieś po około 10 godzinach doszło do 20 stopni.
  7. Oczywiście, że się da. Metoda nr 1 ustawiasz n a czujniku pokojowym 30 stopni i grzeje Ci non stop aż dojedzie w chacie do 30 stopni. Możesz też puścić cieplejszą wodę w kaloryfery. Metoda nr 2 jak nie ma czujnika pokojowego to zapewne trzeba zewrzeć odpowiednie styki w sterowniku czyli zrobić dokładnie to samo co robi właśnie czujnik pokojowy. Pozdr, tomek
  8. Właśnie, dobre pytanie. Jak mam ustawione obniżenie na 40 stopni, to w momencie kiedy sygnał od czujnika pokojowego daje znać, że jest już ok, to pompa grawitacyjna całkowicie mi się wyłącza, ale zawór czterodrożny pozostaje w takiej pozycji w jakiej przyszedł sygnał od czujnika pokojowego, czyli rzadko kiedy zamknięty. Czyli więc grawitacja może pchać wodę w kaloryfery?
  9. A może wysunął się czujnik z bojlera. U mnie kiedyś syn się kręcił w kotłowni i wyciągnął zupełnie ten czujnik, woda grzała się do 60 stopni, nawet to czułem pod kranem ale mózg działa z pewną bezwładnością i dopiero po kilku dniach zajrzałem do kotłowni bo coś za często się właśnie piecyk włączał.
  10. Trochę późno, ale u mnie przepust robili później. Na ławie mam fundament z bloczków i elektryk przewiercił się przez te bloczki. Mają teraz dobre wiertarki i zajęło mu to może z 5 minut. Faktem jest, że nie miałem jeszcze wylewki w garażu więc nie musiał przebijać się przez podłogę. Pozdr, tomek P.S. Jak będę miał trochę czasu, to poczytam sobie Twój dziennik, bo jakoś go przegapiłem.
  11. U mnie luba też marudziła, że strasznie zimno, więc trzeba było puścić ciepełko w kaloryfery. Nawiasem, z barlinka który zamówiłem nic nie wyszło, w zamian dostałem 5ton pellet braci Mrozik 6mm, na razie wygląda ok, daje trochę więcej popiołu ale nie daje spieków. Mam też na testy 1t pelletu 8mm jakiegoś innego producenta. Pozdr
  12. Ciekawe z tymi przegrzaniami, bo u mnie nie było takowego od momentu kiedy znalazłem i zlikwidowałem nieszczelność w zasobniku, czyli gdzieś około 2 lat. Mam u siebie zainstalowany regulator ciągu, może to dzięki niemu. Komin 8,5m, 16mm ceramiczny, wyjście komina bez żadnych strażaków, daszków. Wyczystka zamknięta szczelnie. Pozdr, tomek
  13. Ja dla przykładu w nowym domu postawiłem sobie kominek otwarty, rocznie palę w drzewo za ok. 500zł (1m3 dąb, brzoza 200zł w okolicach Warszawy) i tak naprawdę idzie w większości to w komin. Ale nie lubię patrzeć na ogień przez szybę, bo dla mnie to tak jak oglądać zachód Słońca nad morzem przez okno. Wniosek stąd taki, że nie każdą kWh człek żyje, ale również przyjemnościami. Pewni ludzie tego nie rozumieją, ale dla moje rodziny wspólnie spędzony czas przed tym kominkiem to niezapomniane chwile. Co do kosztów, to ja zapłaciłem, za poprzedni rok, za grzanie i wodę za 12 miesięcy coś koło 4300zł, dom 160 pow. użytk.+40m garaż (w garażu temperatura w najgorsze mrozu nie spadła mi poniżej 14, zwykle mam tam 18-19 st.). W tym roku będzie podobnie albo nawet lepiej, bo pelletu mi trochę zostało. Nie mam żadnej rekuperacji bo nie lubię tego typu wynalazków, więc wynik moim zdaniem bardzo dobry, biorąc pod uwagę, że temperatura w domu ustawiona była zawsze na 22st. Nie prezentuję filozofii waflosa ale zgoła odmienną, niestety najwyraźniej on tego nie rozumie i uparcie stara się przekonać do jedynych słuszności. Waflos, moja rada jest taka, żebyś jednak odpuścił sobie ten wątek, jeśli ktoś będzie zainteresowany to na pewno znajdzie ten o prądzie. Tutaj piszemy o granpalu i tylko zaśmiecasz ten wątek. Nie intersuje mnie dom pasywny, grzanie prądem, rekuperaktory, srory i inne duperele. Interesuje mnie granpal. Proszę więc nie pisz więcej tutaj jak nie masz nic do powiedzenia w temacie.
  14. Widzisz waflos, ja spojrzałem na rachunki i średnie zużycie prądu miesięcznie waha mi się od 270 do 370. Dodam, że mam większość żarówek energooszczędnych w tym też diodowe. Prąd zużywam tylko na to co potrzebuję czyli kuchnia elektryczna, zmywarka raz dziennie, pralka, lodówka, tv (mało oglądam) plus komputery (mam takie hobby do którego potrzebuję 3 komputerów właczonych 12godz/dobę (ale to stare kompy więc prądu jedzą mniej). Żona dużo pierze bo dwójka małych dzieci. Tak więc trochę bym jednak tracił na tej dziennej taryfie, bo jednak nie wyobrażam sobie, żebym miał zmuszać żonkę do prania w nocy. Takie wyliczenia jak Twoje może są korzystne ale w Twojej sytuacji, w mojej raczej by to tak już nie wyszło.
  15. waflos, to ciekawe. Zastanawia mnie kiedy puszczasz zmywarkę, pralkę, etc. Ja mam dwójkę małych dzieci i pralka chodzi średnio 2 razy dziennie, nie raz po 4 razy jak wracamy z dłuższych wyjazdów. I niby co, mam prać w nocy? Albo zmywać naczynia nie wtedy kiedy są brudne ale czekać na tańszą taryfę w nocy? Moim celem w życiu jest żyć zdrowo i komfortowo i nie patrzeć na liczniki Nie możesz korzystać z prądu tyle co ja, bo miałbyś wyższe rachunki więc wnioskuję, że Ty życie podporządkowujesz licznikom i to one pokażą. Chyba, że mieszkasz sam w tym domu, to mogę uwierzyć w tak niskie rachunki.
  16. Waflos, puste gadanie. Wróć na to forum za 12 miesięcy i pokaż ile zabuliłeś za prąd. Bo takie Twoje gadki to ja znam. mam kilku znajomych co to grzeja gazem i każdy z nich ma zimniej w chacie, jak dla mnie za zimno. A rachunkow jakos niskich to nie maja. Jak znam życie, to Ty siedzisz w polarze twierdzac, ze tak jest zdrowiej. Koncze swoj glos w tej jalowej dyskusji. pozdr
  17. Powiem Ci, że strasznie męczysz waflos. Co do pradu to nie wiem ile place, nie wczuwam sie w to za bardzo, bo nie mam czasu, nie jestem typem czlowieka, ktory patrzy tylko na liczniki i przelicza to na zlotowki. Mam dom i chce sie w nim czuc dobrze wiec po prostu mieszkam a nie licze. Jak Cie interesuje moge Ci opdać ile zapłaciłem za prąd, pellet i dołożyć do tego wykres temperatury w chacie i na dworze. Można z tego wysnuć jakieś wnioski, bo z Twojego pisania na razie niewiele wynika. Pozdr, tomek
  18. Mam dom z cienkiego bala lub z grubej deski jak kto woli: bal 7cm + ekofiber 15cm + bal 7cm, nie dawałem folii. Nie rozumiem co piszesz o tym uwalnianiu. Tak nawiasem górale z z\dawien dawna budowali bez folii i do dzisiaj ich chaty stoją. Rekuperacji nie chciałem bo lubię zasypiać w błogiej ciszy, to mi przypomina czasy kiedy jako dziecko spałem na wsi u dziadków. Kończę dyskusję w temacie, każdy robi według swoich przemyśleń i upodobań, zawsze są plusy i minusy. Pozdr
