xisio
Zawartość dodana przez xisio
http://img694.imageshack.us/img694/278/dsc04602y.th.jpg Więcej zdjęć w poscie http://forum.muratordom.pl/wnetrze-do-oceny,t164074-79.htm Tutaj film z działania różnych trybów sterownika, jak jest najszybszy to można dostać kręćka. http://www.youtube.com/watch?v=Pqc-OD9nuI0 Tutaj troche wolniej http://www.youtube.com/watch?v=vp4pM223KiM Poniżej link jak to wszytko wygląda z włączonymi halogenami http://www.youtube.com/watch?v=sqzOcKzWdDM a tak widzą to sąsiedzi http://www.youtube.com/watch?v=iv1OuMXjhhU
15m taśmy led, 2 godziny montażu i połowa sąsiadów na balkonach http://img691.imageshack.us/img691/5711/dsc04567m.th.jpg http://img689.imageshack.us/img689/6966/dsc04568.th.jpg http://img694.imageshack.us/img694/2475/dsc04569.th.jpg http://img682.imageshack.us/img682/2407/dsc04588.th.jpg http://img213.imageshack.us/img213/5874/dsc04589i.th.jpg http://img211.imageshack.us/img211/5005/dsc04590.th.jpg http://img265.imageshack.us/img265/8993/dsc04591t.th.jpg http://img694.imageshack.us/img694/5632/dsc04592.th.jpg http://img410.imageshack.us/img410/3216/dsc04593o.th.jpg http://img691.imageshack.us/img691/2661/dsc04594u.th.jpg http://img213.imageshack.us/img213/8356/dsc04595k.th.jpg http://img694.imageshack.us/img694/278/dsc04602y.th.jpg http://img265.imageshack.us/img265/6987/dsc04603.th.jpg http://img682.imageshack.us/img682/2574/dsc04604.th.jpg http://img410.imageshack.us/img410/5336/dsc04605.th.jpg http://img32.imageshack.us/img32/6089/dsc04613tj.th.jpg http://img691.imageshack.us/img691/5690/dsc04614.th.jpg http://img410.imageshack.us/img410/4240/dsc04615y.th.jpg http://img213.imageshack.us/img213/9831/dsc04616j.th.jpg http://img265.imageshack.us/img265/7770/dsc04617.th.jpg http://img694.imageshack.us/img694/9430/dsc04618.th.jpg http://img682.imageshack.us/img682/5562/dsc04619.th.jpg http://img211.imageshack.us/img211/4615/dsc04629z.th.jpg http://img694.imageshack.us/img694/7608/dsc04630.th.jpg http://img32.imageshack.us/img32/913/dsc04631w.th.jpg http://img18.imageshack.us/img18/3797/dsc04632a.th.jpg http://img410.imageshack.us/img410/9963/dsc04633y.th.jpg http://img32.imageshack.us/img32/6061/dsc04634jj.th.jpg http://img18.imageshack.us/img18/3946/dsc04559t.th.jpg http://img691.imageshack.us/img691/2870/dsc04560.th.jpg http://img682.imageshack.us/img682/4114/dsc04561m.th.jpg http://img20.imageshack.us/img20/803/dsc04562t.th.jpg http://img130.imageshack.us/img130/3766/dsc04564.th.jpg http://img25.imageshack.us/img25/7089/dsc04565p.th.jpg http://img410.imageshack.us/img410/4448/dsc04566z.th.jpg
pobór prądu : 2A / 5m czyli masz 24W na całą rolkę, zasilacz 30W wystarczy, trzeba pamiętać że sprawność zasilacza jest najlepsza przy 70-90% obciążenia wiec 30W jest ok i najmniejsza strata prądu. W taśmach led w jednym kolorze nie masz problemu liczysz całą moc i działa, sterownik dla tych taśm jedynie sciemnianie czy miganie moze dać. Kup zasilacz 30W najlepiej taki http://allegro.pl/item807293208_okazja_zasilacz_sieciowy_led_30w_led_lux_pl.html bedzie ok dla jednej taśmy 5m.
Taśmę można ciąć co 10, 5, 3 cm ( w zależności czy masz 150,300,500 diód) Co pkt ciecia, masz złącza co pkt ciecia mozna stosować specjalne złączki wsuwane. Co 50 cm masz punkty lutownicze z cyną, na upartego mozesz sam lutować co pkt ciecia ale problemem jest czasem trzymanie cyny trzeba odpowiednią lutownicą z kalafonią by nie spalić taśmy. Zasilaczy używałem kilka, w tym jeden od laptopa 12v z obciętą wtyczką i działą super. Polecić mogę tego typu http://allegro.pl/item798442061_zasilacz_100_wat_dc12v_prad_staly_listwa_led_nowy.html ew wodoodporne http://allegro.pl/item801180958_zasilacz_wodoodporny_12v_dc_60w_5a_idealny_do_led.html ten pierwszy jest lepiej wykonany i dopracowany. Dobrą opinia cieszą sie zasilacze meanwell ale naprawde to tylko naklejka i jest identyczny jak ten pierwszy co podałem http://allegro.pl/item786739229_zasilacz_impulsowy_do_led_rs_100_12_12v_100w.html Należy pamiętać ze jak podłączamy diody to poza mocą zasilacza trzeba uwzględnić obciązenie sterownika (szczególnie rgb) jak listwa bierze np 36W na napięciu 12v to jest to 3A jak damy 3 listwy (15 metrów rgb) do sterownika np tego http://allegro.pl/item803906685_sterownik_kontroler_rgb_do_tasma_listwa_led_pilot.html to moze nie wytrzymać bo max ma 2A na kanał ( w sumie 6A ale pamiętajmy ze każdy kolor ma inny pobór mocy jeszcze i moze na kanale jednym być 3A a inne 2A i 1A) Dodatkowo nie powinno sie podłączać taśm szeregowo, najlepiej przy 3 taśmach wyprowadzić od zasilacza/sterownika 2 kable jeden np 2m do sufitu, drugi 2m+5m czyli od zasilacza do sufitu i dalej do końca taśmy. Wtedy 2 taśmy podłączamy do krótkiego kabla w przeciwnych kierunkach, a jeden na końcu taśmy do 7m kabla. Dodatkowo trzeba unikać by listwy były np 5+5+2 wtedy ta 2m moze świecić mocniej niż inne. Lepiej wszytkie uciąć ~4m
Wyłączniki będą martena seria arc m-plan, lub sistena life one z legranda, albo kremowe albo drewniane. Nie wiem jeszcze bo trudno dostać bardziej zaawansowane sciemniacze czy sterowniki rolet na podczerwień w pl, a jak juz są to za sterownik do rolet na podczerwień i reczny trzeba 650zł zapłacić... więc jak liczyłem gniazdka do samego salonu ponad 2500zł z głośnikowymi, sieciowymi itp... Poczekaj do końca projektu jak będzie kanapa sprzet rtv i projektor zamocowany. Efekt będzie lepszy. Cały czas zastanawiam sie nad kolorem kanapy ale będzie chyba kremowa, jasny długowłosy dywanik i szklana ława. Nie wiem czy robić jakieś firanki... Co do sypialni to: farba tikurrila z mieszalnika. na ścianie jasny i ciemny brąz w pełnym macie. kwiat odmalowany z szablonu w optiva 25 (połysk) kolor ten sam co na ścianie tylko inna baza. Całość jest na 2 płytach k/g szerokość 210cm tyle co łóżko, po bokach będa ledy zapalane z kontaktu.
ja wczoraj zamontowałem 14m listwy led ciepłej. W sobote robię 15m RGB wkoło salonu. Więcej zdjęć z holu i łazienki co do led tutaj http://forum.muratordom.pl/wnetrze-do-oceny,t164074-60.htm
Poniżej kolejne postępy z pracy, niestety aparat kiepsko kolory od taśmy led odzwierciedla, na żywo są bardziej białe i naturalne. Kolor farby to sun flower z beckers designer. http://img41.imageshack.us/img41/2718/dsc04490xe.th.jpg http://img39.imageshack.us/img39/1952/dsc04491h.th.jpg http://img38.imageshack.us/img38/6151/dsc04492i.th.jpg http://img41.imageshack.us/img41/9784/dsc04494u.th.jpg http://img691.imageshack.us/img691/3691/dsc04496.th.jpg http://img38.imageshack.us/img38/4085/dsc04499u.th.jpg http://img41.imageshack.us/img41/9520/dsc04500p.th.jpg http://img691.imageshack.us/img691/1993/dsc04502e.th.jpg http://img91.imageshack.us/img91/5978/dsc04503.th.jpg http://img691.imageshack.us/img691/3104/dsc04506y.th.jpg http://img38.imageshack.us/img38/8361/dsc04508pl.th.jpg http://img41.imageshack.us/img41/2006/dsc04517k.th.jpg http://img193.imageshack.us/img193/8092/dsc04518b.th.jpg http://img193.imageshack.us/img193/8523/dsc04519q.th.jpg http://img43.imageshack.us/img43/7359/dsc04529rq.th.jpg http://img41.imageshack.us/img41/7726/dsc04531s.th.jpg http://img687.imageshack.us/img687/7101/dsc04533t.th.jpg http://img193.imageshack.us/img193/1697/dsc04544gp.th.jpg http://img691.imageshack.us/img691/6732/dsc04551y.th.jpg http://img91.imageshack.us/img91/8042/dsc04552p.th.jpg
taśmy led są produkowane przez kilku producentów na wschodzie. różnią sie jedynie ilością diód na metr, są 150, 300, 600. Trzeba pamiętać że ilość pobieranych W wzrasta z ilością diód... reszta to ta sama taśma klejąca 3M i w 90% te same diody od jednej firmy.
na power led to i tak niezła cena zwykłe ledy też sie okazuje że są nawet w pl. http://www.luxmarket.pl/asortyment/inni/zarowka-led-qrb-38w-g53/4470 http://www.luxmarket.pl/uploads/assortment_images/midi/a-4470-8829.jpg
morfeusz znalazłem coś dla Ciebie na G53. http://www.ledlamps-lighting.com/AR111_12v_DC_7w.JPG http://upload.wikimedia.org/wikipedia/commons/f/fa/G53.JPG
a jakie jest twoje pytanie ? Bo jezeli pytasz tak ogólnie mozna i świeci.
Uważaj z tym paleniem i spaniem, bo jak w sypialni to mozesz juz nie napisać kolejnego posta na tym forum jak napalisz dobrze. Sprawdz komin i połączenia !!!
BECKERS - farba, farby: opinie, kolory, malowanie, rodzaje
xisio odpowiedział asia.malczewska → na topic → Wnętrza
odpisał mi beckers: 1. Designer Vaggfarg Helmatt [3] VIT - biała farba do bezpośredniego zastosowania, 2. Designer Vaggfarg Helmatt [3] VIT - w bazie A, 3. Designer Vaggfarg Helmatt [3] VIT - w bazie C, przy czym bazy służą do zakolorowania w systemie Beckersa. Oznaczenia znajdują się przy kodzie kreskowym. Baza A służy do zakolorowania na jasne kolory, baza C na ciemne, nie należy ich stosować w postaci nie barwionej. dziwne troche bo mam 4 rodzaj farby puszkę Designer Vaggfarg Helmatt 3 bez dopisku vit albo baza A/C- 128 odpowiedzi
Witam Kupiłem ostatnio puszkę farby pełny mat (designer 3) w sklepie patronackim firmy beckers, wszytko fajnie wiec chciałem kupić wiecej i w supermarkiecie (obi ale tez i inne) znalazłem tą farbę ale wszędzie w oznaczeniach ma naklejkę "VIT" (z przodu puszki i kod paskowy) ta co kupiłem wcześniej nic takiego nie ma. Na infolinii beckersa panna nie wiedziała co to oznacza i zaczeła mi smucić ze to co bez naklejki to baza a z naklejką to biały kolor ( bzdura bo w sklepie sprzedali mi jako normalną białą i świetnie wygląda a puszka i opis identyczny poza napisem VIT. CO TO MOZE OZNACZAĆ ? czy z supermarketu jest inna ?- 128 odpowiedzi
trzeba było troche dac akcent na tej ścianie, bezie odbijac sie w lustrze, tak to by było zbyt kremowo w tym rogu.
- 1 685 odpowiedzi
- "na
- (domino)
(i 35 więcej)
- "na
- (domino)
- -znacie?
- aldea
- aranżacje
- beton
- beżowa
- braid-kto
- chyba
- colour
- concrete
- domino
- femme
- glazura~gres~terakota
- kuba
- majolika
- marce
- nostalgia
- nowoczesna kuchnia
- opinie
- pliss...
- plytki
- prośba
- płytki
- sasso
- satin
- syria
- szary
- tubądzin
- tubądzin-kto
- tubadzina
- ułożona
- zdjęcia
- żywo"
- łazience-pochwalcie
- łazience?
- łazienka
To teraz ja troche z postępów z alabastrino. Zdjęcia zrobione na szybko po fugowaniu scian, jeszcze brudne ale juz widać zamysł. Na razie nie ma zlewu i kibelka docelowego tak samo kabiny. http://img16.imageshack.us/img16/7724/dsc04380ai.jpg http://img269.imageshack.us/img269/301/dsc04382g.jpg http://img19.imageshack.us/img19/570/dsc04391w.jpg http://img15.imageshack.us/img15/3674/dsc04392o.jpg http://img15.imageshack.us/img15/1148/dsc04393za.jpg Komentarze mile widziane.
- 1 685 odpowiedzi
- "na
- (domino)
(i 35 więcej)
- "na
- (domino)
- -znacie?
- aldea
- aranżacje
- beton
- beżowa
- braid-kto
- chyba
- colour
- concrete
- domino
- femme
- kuba
- majolika
- marce
- nostalgia
- opinie
- pliss...
- plytki
- prośba
- płytki
- sasso
- satin
- syria
- szary
- tubądzin
- tubądzin-kto
- tubadzina
- ułożona
- zdjęcia
- żywo"
- łazience?
- łazienka
PANASONIC plazma 42-50 cali.....który polecacie
xisio odpowiedział siemka → na topic → AGD i RTV w domu
za te pieniadze to kup samsunga b8000 albo sony z5500 mniej prądu a obraz żyleta. -
ceresit cm17 klej i fuga tez tej firmy elastyczna, widziałem ostatnio klej do gresu ceresit cm12 chyba ale znam o nim opinii.
juz widac ok
- 1 685 odpowiedzi
- "na
- (domino)
(i 35 więcej)
- "na
- (domino)
- -znacie?
- aldea
- aranżacje
- beton
- beżowa
- braid-kto
- chyba
- colour
- concrete
- domino
- femme
- kuba
- majolika
- marce
- nostalgia
- opinie
- pliss...
- plytki
- prośba
- płytki
- sasso
- satin
- syria
- szary
- tubądzin
- tubądzin-kto
- tubadzina
- ułożona
- zdjęcia
- żywo"
- łazience?
- łazienka
Wgraj zdjecia na http://imageshack.us/ i podaj linki do web forum link bo z picasa cos źle wkleiłaś.
- 1 685 odpowiedzi
- "na
- (domino)
(i 35 więcej)
- "na
- (domino)
- -znacie?
- aldea
- aranżacje
- beton
- beżowa
- braid-kto
- chyba
- colour
- concrete
- domino
- femme
- kuba
- majolika
- marce
- nostalgia
- opinie
- pliss...
- plytki
- prośba
- płytki
- sasso
- satin
- syria
- szary
- tubądzin
- tubądzin-kto
- tubadzina
- ułożona
- zdjęcia
- żywo"
- łazience?
- łazienka
Kanapa powinna mieć 225cm szerokości w mniejszym boku, bo tyle ma sciana pod oknem. Ta jako jedyna chyba z helvetia miała, poza tym tak kwadratowe jak pokazałaś wydają mi sie bardzo twarde i mało wygodne... nie mówiąc ze nie rozkładają sie do spania. Zdjęcia juz nie długo, obecnie wklejamy narożniki, gipsujemy i kończymy łazienkę dziś zrobię trochę zdjęć łazienki.
Morfeusz niestety nie pasuje nic, masz tam trasformator 12v na halogen na trzonku G53 takie ledy na g53 nie mogą mieć odbłysnika i dławika na lampie i wyglądają tak: http://www.swiatlo-led.pl/produkt-zarowka-ar111-led-10w-25-stopni-4000k_6119.html A kazdy co twiedzi ze za 30zł kupi 100led oprawkę i będzie miał fajne jasne światło jak 50W wprowadza niestety w błąd. Na razie technologia dopiero raczkuje i najbezpieczniej kupować halogeny na GU10 i za kilka lata wsadzić w to same żarówki led. Obecnie coś warte ledy to np http://allegro.pl/item735640975_high_power_led_us_cree_xre_3x2w_gu10_420lm.html ale cena zabija.
Niestety troche przesadzona jest ta wypowiedz, by LED dał tyle światła co 50W musi to być żarówka złożona z 3 powerled dobrej firmy np US CREE model XRE Niestety żarówka która naprawde świeci pobiera min 6-8W i kosztuje powyżej 100zł. Każda inna szczególnie te z 100led w oprawce są do pupy. Co do halogenów to kupować trzeba takie jakie sie podobają byle były na żarówkach z trzonkiem GU10 i wtedy każdą led można wsadzić.
Z przełącznikami jest mały problem bo: 3 po prawej do sterowania swiatłem w holu i są to krzyżowe wiec muszą być pojedyncze ;/ są włączane w 3 miejscach. 1. Halogeny na holu. 2. Ledy w koło holu światło wypada na sciany z sufitu 3. zabudowa k/g na holu mała drewniana szafka po prawej. 4 po lewej to: 1. włącznik podwójny do światła na środku pokoju (plafon jakiś 2 żarówki) 2. Ściemniacz do halogenów. 3. włącznik podwójny do led na suficie i led w wnęce za tv. 4. opuszczanie ekranu. Nie mam z czego zrezygnować za bardzo :/ Chce dać ładne drewniane ramki Legranda sistena life i będzie ładnie, tylko cena ramek mnie powala na razie jak sie policzy z klawiszami i wkładami. Generalnie kanapa będzie helvetia model westlife new w kremowej skórze. http://www.helvetia.com.pl/upload/helvetiadb_1669.jpg pod tv będzie jakaś szafka na 3x2 sztuki sprzetu HIFI a po bokach stojące kolumny, nad kanapą na ścianie jak juz wspomniałem kilka obrazów tworzących jeden. Mam problem na razie z dobraniem jedynie kolorów podłogi i scian. Co do led oczywiscie będą RGB w koło salonu i za tv, na holu będą zwykłe ciepły biały. sterownik radiowy tego typu http://ledmasters.pl/component/virtuemart/?page=shop.product_details&flypage=flypage.tpl&product_id=25&category_id=8 zrobiłem juz pod niego okablowanie.
Postaram sie zrobić dokładne howto dla led. Chce użyć sterowania LED za pomocą sterownika radiowego tak by każdy kolor led był oddzielnie sterowany i można było dobrać jasność, kolor i ew efekty do danej chwili Ekran jest zabudowany i zwijany elektrycznie firmy Avers model Contour z ramką czarną wkoło. http://business-group.pl/sklep-abc/pic/Ekran-elektryczny-do-zabudowy-Avers-Contour-180x102-cm-_bp2396.jpg Do tego bedzie projektor przy oknie 5 cm od sufitu tak jak jest mocownie na zdjęciach. Kable do projektora (9 sztuk) i głośników pochowane są w zabudowie i ścianach. W jadalni/kuchni przeszkadzała belka wiec dobudowałem belkę do 165cm od sciany i wejdzie zabudowa wysoka 60/45/60 dalej będzie blat i zabudowa nad szafkami na 32cm tyle co standardowe szafki. W rogu dałem zlew po lewej stronie bedzie pralka (jest dziura do garderoby by zmieścić tył pralki w szafce) po prawej bedzie zmywarka i płyta. Dodatkowo dałem czujką zalania i dymu w kuchni. W jadalni Faktycznie te 4 halogeny są moze za duzo ale nie wiedziałem jak zakończyć sufit a nie chciałem robić kolejnej dziury w suficie, na początku chciałem nad stołem powiesić lampę ale nie wiem dokładnie gdzie będzie stał stół jeszcze wiec profilaktycznie pociągnołem k/g do belki i zrobiłem halogeny. Zabudowa od tv bedzie będzie obłożona kamieniem z gipsu i pomalowana na jaśniejszy kolor niż sciany. W rogu planuje kremową kanapę skórzaną z helvetia oraz jakiś tryptyk albo inny duży obraz na scianę złożony z mniejszych. Lubie tego typu nowoczesne wnętrza i wiem ze bede sie czuł dobrze w czymś co sam wymyśliłem i zrobiłem.
