WYKONUJĘ TYNKI MASZYNOWE GIPSOWE ORAZ GŁADZIE GIPSOWE MULTI FINISH. CZYM SĄ TYNKI MASZYNOWE GIPSOWE WIE KAŻDY PRZYBLIŻĘ NATOMIAST PAŃSTWU POJĘCIE MULTI FINISH ALBOWIEM JEST TO PRODUKT RZADKO SPOTYKANY NA NASZYM RYNKU. MULTI-FINISH JEST GIPSOWĄ MASĄ WYKOŃCZENIOWĄ, BEZPYŁOWĄ (TZN., ŻE NIE WYMAGA SZLIFOWANIA!!!).
BEZPYLOWA TECHNOLOGIA GLADZI GIPSOWEJ "BRITISH GIPSUM"
* GLADŹ WYKONYWANA NA MOKRO AZ DO UZYSKANIA EFEKTU LUSTRZANEGO SCIAN ,SUFITOW ITP.
* BEZ KONIECZNOSCI DOCIERANIA SIATKAMI, SZLIFOWANIA JAK SIE TO MA PRZY ZWYKLYCH GIPSACH POLSKICH I CO ZA TYM IDZIE MASA KURZU I BALAGANU
PLUSY MULTI-FINISHU:
* BEZPYŁOWY EFEKT GŁADKOSCI ŚCIAN ,SUFITÓW ITP.
* ODPORNIEJSZY NA PĘKNIECIA
* A CO NAJWAZNIEJSZE MASZ URZADZONE MIESZKANIE ,POKOJ ,MIESZKASZ W M4 I NIE MASZ GDZIE SIE PODZIAC Z RZECZAMI ITD W OBAWIE ,ZE SIE ZAKURZY TO SPOKOJNA GLOWA NIC NIE MUSISZ WYNOSIC
* FARBA NIE LUSZCZY SIE PO CZASIE LUB TUZ PO MALOWANIU JAK SIE TO MA CZASEM PRZY TRADYCYJNYCH GIPSOWKACH
* BEZ KONIECZNOSCI GRUNTOWANIA PRZED MALOWANIEM
* O WIELE TWARDSZY NIZ POLSKA GLADZ GIPSOWA
* ŻĄDANY EFEKT KOŃCOWY W 100% LEPSZY OD TRADYCYJNYCH GIPSÓW POLSKICH ZACIERANYCH NA SUCHO
* MULTI-FINISH JEST GLADZIĄ BEZPYLOWĄ SWIETNE ROZWIAZANIE DLA ALERGIKOW I UCZULONYCH NA KURZ
TECHNOLOGIA TYPOWO ANGIELSKA STOSOWANA I PRAKTYKOWANA PRZEZ NAS OD KILKU LAT.
GWARANTUJĘ 100% DOŚWIADCZENIA I PROFESJONALIZMU. PRACE WYKONUJEMY NA TERENIE DOLNEGO ŚLĄSKA. NAJWAŻNIEJSZĄ DLA NAS RZECZĄ JEST ZADOWOLENIE NASZYCH KLIENTÓW GDYŻ TO JEST NAJLEPSZA FORMA REKLAMY.
TELEFON KONTAKTOWY 791 635 973
https://forum.murator.pl/topic/125672-tynki-maszynowe-g%C5%82adzie-gipsowe-wroc%C5%82aw/
