POMPA CIEPŁA - zużycie prądu
Gość Gosc***
  • Odpowiedzi 13,7k
Piekny ten nasz luty, wczoraj bylo troche chlodniej ale ogolnie trzyma sie w okolicy -2 +1stC. Moje zuzycie:
2013-02 (22 dni, srednia temp: -0.04°C):
SUMA: 649.28 kWh (tania: 485.26 kWh, droga: 164.02 kWh)
KOSZT: 253.87 PLN (tania: 154.31 PLN, droga: 99.56 PLN)
SREDNIA / DZIEN: 29.51 kWh (tania: 22.06 kWh, droga: 7.46 kWh)
SREDNI KOSZT / DZIEN: 11.54 PLN (tania: 7.01 PLN, droga: 4.53 PLN)
PROCENTOWE ZUZYCIE: tania: 74.74% / droga: 25.26%
2013-02-01: 26.31 kWh (tania: 21.21 kWh, droga: 4.75 kWh), temp: 4.24°C
2013-02-02: 31.46 kWh (tania: 20.72 kWh, droga: 7.56 kWh), temp: 3.53°C
2013-02-03: 30.62 kWh (tania: 23.01 kWh, droga: 7.26 kWh), temp: -0.34°C
2013-02-04: 30.93 kWh (tania: 22.40 kWh, droga: 8.25 kWh), temp: 1.72°C
2013-02-05: 28.58 kWh (tania: 22.41 kWh, droga: 5.88 kWh), temp: 3.74°C
2013-02-06: 30.87 kWh (tania: 22.38 kWh, droga: 8.20 kWh), temp: 1.68°C
2013-02-07: 32.00 kWh (tania: 22.99 kWh, droga: 8.66 kWh), temp: -0.26°C
2013-02-08: 31.51 kWh (tania: 22.21 kWh, droga: 9.06 kWh), temp: -1.09°C
2013-02-09: 31.65 kWh (tania: 22.12 kWh, droga: 9.22 kWh), temp: -1.28°C
2013-02-10: 31.92 kWh (tania: 22.42 kWh, droga: 9.21 kWh), temp: -1.91°C
2013-02-11: 31.71 kWh (tania: 22.46 kWh, droga: 8.97 kWh), temp: -1.75°C
2013-02-12: 31.37 kWh (tania: 22.31 kWh, droga: 8.78 kWh), temp: -1.91°C
2013-02-13: 31.81 kWh (tania: 22.59 kWh, droga: 8.93 kWh), temp: -0.50°C
2013-02-14: 31.20 kWh (tania: 22.72 kWh, droga: 8.19 kWh), temp: -0.15°C
2013-02-15: 31.13 kWh (tania: 22.36 kWh, droga: 8.45 kWh), temp: 1.14°C
2013-02-16: 28.56 kWh (tania: 22.45 kWh, droga: 5.78 kWh), temp: 1.50°C
2013-02-17: 29.06 kWh (tania: 23.86 kWh, droga: 4.90 kWh), temp: 1.05°C
2013-02-18: 30.82 kWh (tania: 22.89 kWh, droga: 7.58 kWh), temp: -0.57°C
2013-02-19: 30.55 kWh (tania: 22.93 kWh, droga: 7.27 kWh), temp: -0.01°C
2013-02-20: 31.46 kWh (tania: 22.92 kWh, droga: 8.19 kWh), temp: -1.39°C
2013-02-21: 31.17 kWh (tania: 22.40 kWh, droga: 8.49 kWh), temp: -3.92°C
2013-02-22: 14.08 kWh (tania: 13.49 kWh, droga: 0.44 kWh), temp: -4.42°C
Bardzo podobny do stycznia. Przynajmniej u mnie.
-------- Okres: 2013-02-01 do 2013-02-22 13:57:26 (21,58 [d]) ---------
Czas pracy CO: 184,49 [h] (88,7%)
Czas pracy CWU: 23,61 [h] (Cykli: 70) (Średnio dziennie: 3,2)
Suma pracy PCi: 208,1 [h]
Startów: 78 (Średnio dziennie: 3,6)
Czas pracy śr CO: 8,55 [h/d]
Czas pracy śr CWU: 1,09 [h/d]
Czas pracy śr: 9,6 [h/d]
Szacowane zużycie: 715 [kWh] Średnio: 33,1 [kWh/d]
CWU: 116 [kWh] Średnio: 5,4 [kWh/d]
CO: 600 [kWh] Średnio: 27,8 [kWh/d]
CO/100m2: 12,1 [kWh/(d*100m2)]
Koszt [2/98%]: 235 zł w tym CO [1/99%]: 193 zł CWU [7/93%]: 42 zł
ale co ma okazja do tego, skoro dla klimatu palisz...znam takich co dla klimatu codziennie palą w kominku :p
nie takie przypadki tu byly...
Przy czujce zewnętrznej niewiele kWh zaoszczędzi, tym bardziej jak otwiera w tym czasie okna.
A pro po. Zmieniłem sterowanie z pogodowego na pokojowe. Jak wszystko dobrze poustawiam to rozpalę w kominku i poobserwuję jakie "oszczędności" z tego wyjdą na podliczniku.
U mnie od miesiąca też nie było palone. Drewno mi się kończy po czterech latach :D
Przy pokojowym moze Twoja PCi to jakos lepiej zauwazy. Moja olewa spalenie polowy paczki brykietu prawie calkowicie. Faktem jest, ze wtedy duzo intensywniej wentyluje.
W przyplywie euforii dla kominka chcialem sobie zamowic palete brykietu "na zapas". Jak mi sie zapal utrzyma na obecnym poziomie, to mial bym na 12-15 lat palenia ;)
Rafik W będę obserwował twoje zużycie bo mamy podobne domy wynikające z twego opisu. Mój różni się tym że ja mam pc HPK 9 TEW i pionowy odwiert 2 *100 m
No to czas podać pierwsze wyniki z podliczników za jeden tydzień (16.02.2013 13:00 - 23.02.2013 13:00):
C.O.
tania: 120,8 kWh - 80,71%; droga: 23,3 kWh - 19,29%. SUMA: 144,1 kWh. Koszt: 49,23 zł
C.W.U.
tania: 20,8 kWh - 52,88%; droga: 9,8 kWh - 47,18%. SUMA: 30,6 kWh. Koszt: 11,99 zł (procentowo dużo wyszło w drogiej bo urlop 4 dni w tygodniu i grzanie oraz pompka cyrkulacji c.w.u. były "uwolnione" od taryf)
Średnio na dobę 24,96 kWh na C.O. i C.W.U tj. 8,75 zł
Temp. w domu: około 23,5 st.C w łazienkach (wahania od 22,5 do 24,2) 21,0 st. C w sypialniach (wahania od 20,5 do 21,5) 21,5 st.C w salonie i kuchni.
Temp. zewnętrzne w granicach -1 -4 st.C.
Trzy osoby zużycie wody około 9 m3 na miesiąc.
PCi do C.O. pracowała około 10 godzin na dobę: 6 godzin w przedziale 22:00-6:00 i 4 godziny w 13:00-17:00.
Za ten sam okres u mnie 116 Kwh za ogrzewanie domu i wody w jednej taryfie. Niestety nie wiem jak rozbić co od cwu. W domu 22-23*C na parterze do 23-24*C na gorze. Za cały luty do dzisiaj pracowała średnio 7 godz/dobę. Pc gdy grzeje wodę zużywa ok 2 Kwh prądu zczytane z licznika.
Bardzo dobry wynik ! Gratuluję.
Kosztowo wyszło u mnie 61,22 zł (G12w) u Ciebie przy jednej taryfie wychodzi 52,91 zł (przy założeniu opłaty w jednej taryfie tak jak w Enerdze w woj. pomorskim, tj. 0,4562 zł za 1kWh.)
PS. Przy takich temperaturach to długo byśmy nie wytrzymali :-) Jednak preferujemy ciut niższe...
Pozdrawiam,
Ja też myślałem że gdy będzie podłogówka to będę miał niższą niestety myliłem się dy była niższa temp w domu to nam było zimno
Jesli to odczyt z jekiegos termometru "pokojowego", to pomylka moze byc nawet o 1,5*C. Ja wg termometru takiego elektronicznego na parterze mam 23.2*C a u gory drugi identyczny pokazuje 23,6*C. Niestety o 1,0-1,2*C zawyzaja odczyt. Nie zdziwie sie, jak u Ciebie bedzie podobnie.
Odczyt na dole tak z termometru elektronicznego z przewodem temp zewn.Ten na kablu leży na podłodze i pokazuje temp podłogi która zgadza się z termometrem w pc dlatego myślę że pomiar jest dobry. Termometr stoi 0,5m nad podłogą. Na górze pomiar metr nad podłogą ze sterownika od rekuperatora na środku korytarza. Na górze czuć że jest cieplej więc myślę że temp się zgadza. Z fizyki pamiętam że ciepło idzie do góry. Jak wiesz z podłogówki którą ogrzewasz dom ciepełko też idzie w górę.
