Temperatura zasilania 55'C
Klimat średni
Pan wh-sdc05h3e5..... lg hu051.u43 ....ariston nimbus40s.....buderus odu-6i
Moc znamionowa Prated..............4kw...........6kw..........4,78kw......5kw
Temperatura biwalenta Tbiv...............-10'C...........-10'C.........-7'C........-10'C
Temperatura limitu działania TOL.......-10'C...........-15'C.......-20'C......-20'C
Temperatura limitu działania WTOL.....55'C............57'C........60'C.......60'C
Dla temperatury wewnętrznej 20'C i temperatury zewnętrznej Tj= -7'C
Moc deklarowana przy częściowym obciążeniu Pdh ,wydajność deklarowana COPd
Pdh................3,5kw...........5kw..........4.23kw.....4kw
COPd............1,89..............2,0............2,35........2,22
Tj=+2
Pdh................2,2kw...........3kw..........2.76kw......2,4kw
COPd............3,32.............3,0............3,37.........3,42
Tj=+7
Pdh................1,4kw...........1,9kw........1,72kw.....2,1kw
COPd.............4,38..............4,4............4,26.......4,9
Tj=+12
Pdh................1,4kw...........2,4kw.........1,58kw......2,6kw
COPd.............6,6...............7,1..............6,19.........7,53
Tj=Tbiv...........4kw...............5,6kw.........4,23kw......4,5kw
COPd ............1,5................1,8..............2,35.........1,91
Tj=TOL..........4kw................5,6kw.........2,47kw......4,3kw
COPd............1,5.................1,8..............1,52..........1,6
grzałki dodatkowe..........3kw........6kw.........2+2kw......0kw
poziom hałasu wewnątrz.........41db........44db.......36db....?
zewnątrz..........65db........65db.......56db......53db
sprawność n.............. 130%..........126%...........135%.....145%
pobór pradu off mode.......... 0,001 kw..........0,009kw......... 0,011kw.....0,017kw
termostat of mode .....0,020kw...........0,016kw..........0,011kw....0,017kw
standby mode .............0,011kw...........0,009kw.........0,011kw.....0,017kw
ogrzew. karteru..........0,023kw............0,020kw.........0,011kw.....0,026kw
Na podstawie nimbus 40s wartościCOP przy minimalnej i maksymalnej częstotliwości pracy sprężarki dla w35 zobaczcie jakie duże są różnice
-20"C min częstotliwośc .......COP=2,12.......max czestotliwość.....COP=1,70
-15'C-----min =2,43------ max=2,03
-10'C-----min=2,71------- max=2,31
-7'C -----min=2,94--------max=2,61------przy mocy nominalnej 4,09kw=cop3,27-----najwyższy możliwy COP= 3,34
-3'C-------min=3,28-------max=2,92
0"C--------min=3,54-------max=3,14
2"C--------min=3,71-------max=3,16------przy mocy nominalnej 2,8kw=cop 4,12-----najwyższy możliwy COP=4,69
7'C--------min=4,60-------max=3,52-------przy mocy nominalnej 3,5kw=cop 5,11-----najwyższy możliwy COP=6,28
10'C------min=4,89-------max=3,65
12,C------min=5,09-------max=3,73
15"C-----min=5,40-------max=3,84
Edytowane przez codix
https://forum.murator.pl/topic/245611-panasonic-wh-sdc05h3e5-vs-lg-hu051u43-vs-ariston-nimbus-40s-dane-techniczne/
Jak dla mnie to jakoś niezrozumiałe :(
Nie bardzo wiem jak to porównać - natomiast wiele dobrego czytałem o Aristonie i biorę go pod rozważania.
Może trochę teraz bardziej czytelnie.
Ja nie mogę dorwać żadnej dobrej cenowo oferty na Aristona ale jeszcze szukam na panas i lg już mam.
To są dane z obowiązkowych etykiet energetyczych zastanawiają mnie dane że Panasonic podaje że dla tej pompy temperatura działania to -10'C a lg już -15 a ariston -20 ,niewiem czy czasem nie jest tak że pompa panasonica działa przy niższych temperaturach np.do -20 stopni ale jak wcześniej iuż chodziła ,a jak się wyłączy przy np.-17stopniach to już nie ruszy dopiero jak temperatura spadnie do tych -10
Ja mam oferte na aristona tylko, w cenie aristona a nie instalatora. Dobrali mi pompe pod obciazenie calkiem sensownie. Na portalu aukcyjnym sa aristony popros o oferte z montazem cenowo powinien wyjsc drozej od lg i taniej od panasa.
