fansigain 01.02.2023 07:12 Zgłoś naruszenie Udostępnij Napisano 1 Lutego 2023 First tome home buyer here building a new construction in Central Valley, CA. Temps in the summer are dry and typically run upper 90s to 100 + degrees. Temps in the winter range from low 30s to mid 60s. The home is just under 3000 sq.ft and will come with insulation as follows: Exterior walls of living area: 6 inches, R-21 Ceiling area: 14 inches, R-49 The builder is offering extra insulation as an upgrade. $1900 for bedrooms and hallways and $945 for the garage. No info on the thickness or R-value. My husband I don’t know much about insulation. Is this extra insulation needed? Is it worth the extra cost? Are garages usually insulated? Any input is appreciated Cytuj Odnośnik do komentarza https://forum.murator.pl/topic/272093-nowy-dom-budowlany-czy-dodatkowy-pakiet-izolacji-jest-tego-wart/ Udostępnij na innych stronach Więcej opcji udostępniania
